Availability of pic free hitech please?
Hi.
I just want to know where can I download or purchase the latest version of Hitech Pic Free software?
Many thanks.
Hi.
Many thanks.
Hello Avah,
It would have been nice if you specified what version you are exactly looking for. Scouring the net the most plausible option for you would be to purchase the software from http://www.htsoft.com/downloads/ ; this site not only guarantees the safety of your device (from viruses/malware) but it also protects you from potential lawsuits arising from dealing in pirated software. However, if buying is beyond your scope then consider the following links;
1. http://www.sonsivri.to/forum/index.php?topic=935.75
2. http://www.cs.ucr.edu/~eblock/pages/pictools/install.html
Not really confident to say that there is a new version released after the last release, for your information the newest version I found is September 2011. The version I found is -TECH C for PIC18 MCU family for part numbers SW500007, and SW500008 and if you want to buy it, it is $1195 for the pro version, $495 if you choose standard version, and free if it is lite version.
HI-TECH C compiler for PIC18 MCUs now uses the Omniscient Code Generationâ„¢ [OCG] to optimize the system that is a whole program compilation technology, this system is used to give code that is denser and give a performance that is better to develop on PIC18 MCUs. To tell you, the ANSI C compiler is available to use in three levels of operation. You may visit given link to get more information: HI-TECH C COMPILER FOR PIC18 MCUs.
