Available Chrome Streaming Capture Plug in for Download
I am a consistent Google Chrome user. But, I want to free some spaces on my hard disk and ease the download of my streaming files such as video. Is there any way to eliminate the use of third-party downloaders by simply using any available Chrome streaming capture plug in?
Best Answer by Smith Cristina
Answered By 0 points N/A #131199
If you want to save disk space, clear browsing history and decrease extensions.
There are many downloading software which allows downloading from Google Chrome as its downloading speed is not good.
You can use IDM (Internet Download Manager). It is world's #1 downloading software I've ever seen.
I think no other downloading software works as good as IDM.
Whenever you are watching YouTube video, you can download the video using this software.
It helps you to download any music, videos, software faster and easily.
Answered By 0 points N/A #131200
I have read the problem you have been encountered, in this situation i may suggest to you to use some possible way to free some space on your hard disk, here is some step, first clear your history by simple first open your Google Chrome and just simple click the wrench icon in the corner and click clear history. You can also download some add-ons  for Google Chrome like Pop up blocker to eliminate or block some unknown data coming from the website that you open. I may also suggest to you to use IDM (Internet Download Manager) for downloading it will make the file you been downloading compressed.
