Available options for windows vista cleaning tools?
I am looking for windows vista cleaning tools for my PC and I don't know which one is the best to use. I would like expert opinion on the best windows vista cleaning tool available preferably from a trusted source, whether available for free download or purchase. Anyone familiar with windows vista cleaning tools?
Best Answer by Ndubueze Donna
Answered By 0 points N/A #163561
Windows Vista cleaning tool is available on internet. I would like to recommend CCleaner it the one of the best tools for all operating system. There are more tools that can be downloaded like :
1. K cleaner
2. PC decrapifier
Answered By 0 points N/A #163562
Hi Johnny,
There are several cleaning tools you can use. Of course CCleaner which was stated above. I would recommend the free tools below:
1. JetClean this supports Windows Vista PCs and can clean the entire registry in just a few seconds. One setback is that it isn't portable. However it is free and has a user friendly interface.
2. EasyCleaner this is one of the most trusted cleaners around Its interface is a bit outdated but it is portable and free.
3. Advanced SystemCare This is an excellent and free program compatible with Windows Vista that includes the ability to remove some malware, cleans junk and more.
Cheers.
