Hi and good day!
I heard from my friend about the Joomla Extension . So may I ask you, is the radio online Joomla module is the best plug-in to receive radio frequencies straight from the web?
Any help would be nice.
Kurtt Stewart
Available radio online Joomla extension?
I would suggest you to try mod_hoicoi_radio. It can easily be found on Joomla! Extension page (https://extensions.joomla.org/) and will give you just what you are looking for. This module is easy to install and configure and really simple to use.
Once after installing it through your extension manager all you need to do is add your favourite channel names (they should be separated by comma) and their URLs and the module is set up. Also, it will not reload your whole page when used.
If you are looking for something more complicated or different, just go over the Social Media > Audio & Radio Channels section of Joomla! Extension website and I'm sure you'll find what you are looking for.
