Avast AntiVirus Uninstall problem. Help me
10 points
Posted on - 10/01/2011
I am using Avast Antivirus. I am uninstalling this Antivirus using Revo uninstaller. Revo uninstaller are showing until success but Avast are running. I go to control panel> Add or Remove, but not found Avast Antivirus. I also try to delete Avast in Program file but gives error message.
How to remove Avast Antivirus on my pc?
