Avast – during the update process, an interrupt was occurred
I have a computer at my home and I use it for basic purposes. I use unix OS which I upgraded recently. With the friend’s advice, I installed avast antivirus to protect my PC from spyware. I know that avast is 1 rated software.
But during the update process, an interrupt was occurred which terminated the process. Please fix this error so that I can update the database and protect my PC.
Thank you.
