After removing free version of avast i received errors that affected my computer system, is there a way to fix this?
Runtime Error!
Program:E:Program Files
This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information.
Avast Free Anti-virus removal causes error
hello there mam margaret. my suggestion to you is go to start. look for the run command and type msconfig
after the msconfig window appears look for the services tab. under the services is a list of all the services that starts when the systems starts up. to fix this problem first put a check on hide all microsoft services. then disable all. click apply and then ok. restart the pc and check if the problem still occurs. but this is the best way to resolve the c++ runtime error
have a nice day.!
Hello Margaret,
When removing Avast you might have deleted some system application files in the process, and that is why you are getting the error you have posted above. To resolve it you will need to do the following:
You will need to install CCleaner on your computer.
Run it and use it to clear all the problems that are affecting the registry entries which may have been caused by deleting some system files by mistake.
Once CCleaner has finished executing, you should restart the operating system and check if it works just fine.
Hope this helps.
Carl
