Avast msn Plugin Trojan Filtering Doubt
I have this strange problem in avast msn plugin that I'm using. Does it naturally block like all other antivirus ? Fact being normal
According to my experience, as the same as you are using Avast Antivirus, yes, you have to felt doubt on Trojan Virus, Avast can’t handle this kind of virus which may result to your computer shutdown. I uninstall my Avast Antivirus and change it with other Antivirus which can detect and solve Trojan Viruses.
Best regards,
Heather marie
Hi Vhilary,
To overcome this problem I will suggest you to change your Avast settings, to do so follow these steps:
1] Go to Avast control panel click on settings.
2] New window will pop up
3] Click on exclusions.
4] Select file you want to send.
5] Add it to exclusion
6] Save settings.
7] Done
This way you are able to send file which is restricted by Avast.
Notifications
