AVG antivirus virus removal issue
I think there is a problem with the displayed error message you indicated in your post. The code or the error message disappears after the page has been completely loaded. Anyway, I happen to figure out how to display the error message you are saying and here it is:
“File c:windowssystemi8042prt.sys Infection trojan horse agent_r. BAV Result object is white listed (critical/system file that should not be removed)”
Based on the message you received on your computer, it seems that your system has already been infected by a Trojan horse and the worst part of it is that, the virus managed to infect one of Windows’ system files and that’s the reason why the antivirus can’t clean or remove the file. What an antivirus usually does when an infected file has been detected is to move that file to quarantine but in your case, it is not happening because the file is a major system file of Windows located maybe in “C:WINDOWSsystem” or “C:WINDOWSsystem32”. At this stage, the only solution I could think of is formatting your system drive, C, then installing Windows again. Or you can also delete the C partition, create a new one, format it, then installing Windows afterwards.
