jen dessin
Posted on - 10/03/2012
Hi Experts,
Now, I am using AVG 2012 and after installing Avg 2012, Google Chrome is not working properly / blocking. Please suggest me why Avg 2012 blocking chrome? And suggest me the step to step procedure of the solution. Thanks!
Jen Dessin
AVG is blocking Chrome: What are the solutions?
Hi Jen,
Thank you for sending this question in.
AVG 2012 blocking Chrome from accessing website has been a known issue for a wide variety of users. AVG's Identity Protection is that main cause of this issue. Disabling it will make Chrome working normal again. But it will definitely compromise your computer's security. I suggest using another free antivirus, or switching from Chrome.
Hope this helps.
