AVG doesn’t run a complete scan
Avg antivirus doesn't run a complete scan. When I start scanning it goes for like 30% and then stops automatically.
What is the version of your AVG anti-virus? The reason why I asked is because sometimes if your AVG is already out-dated you may need to update it first for it to work or scan completely on your computer. You may do the update directly if you have the AVG Free application. All you have to do is click on the “Check For Updates” button which will let your AVG update automatically. It is important that you perform all the updates from your AVG Interface. Here are the steps on how to do the update directly from your AVG antivirus:
Problems like this happen most of the time in most applications on the computer and can normally be fixed by simply re-installing the affected program or programs. First, check if the program will really stop at certain point by doing it a couple of times. If you are positive that the program will really not continue after reaching a certain point, try re-installing it. It would be best to install it again using the program’s latest version. And since it is AVG, you can download the latest version.
If you are already using the latest version and it is the version that’s causing the problem, try deleting temporary files on your computer.
Empty the recycle bin and then try re-installing your antivirus.
It is true that we all need an antivirus to keep our PC safe and sound. In that case, AVG anti-virus is really a brilliant choice to protect and ensure security on desktop, laptop, notebook etc while surfing internet. But now, the problem is AVG antivirus doesn’t run a complete scan although I am using the latest version. All of your comments were first-class, but Sharath you are a genius, you have presented what I need. Your comments help me to point out the root cause. According to your instruction, after deleting temporary files on my computer, again re-installing my AVG antivirus, then restarting my PC, with surprise I saw, my problem has disappeared and my PC could run smoothly and AVG antivirus would perform well in my system unit. Fixing my problem, I heave a sign of relief as well Sharath take my incessant love for your open minded help.
Notifications
