AVG Internet Security Removal Tool- a necessity
Why should the AVG Internet Security removal tool be used while uninstalling the package? How does it affect my system processes if I uninstall it using standard programs?
If the AVG removal tool is not used to uninstall AVG packages from your system, complete uninstallation doesn't happen by using add/remove programs because of security registry entries which might get corrupted. Various other generic problems like a decline in computer speed, difficulty in connecting to the internet, installation errors increase, and freezing of the systems can also happen. The antivirus can be moved completely using the removal tool available for all processor versions on the official website of AVG, under antivirus removal tools.
