anonymous
7060 points
Posted on - 02/26/2012
I downloaded the Avid Studio Trail but in the wrong language. Is there anyway to change that? I cant even figure when Im at without translating every word. Its the trail version if I uninstall and reinstall will Avid Studio let me continue using it?
Help
Avid Studio Wrong Language Trail
Uninstall and reinstall is the best solution for your problem, but if your trial version is already expired even you uninstall and reinstall it, it will be already expired so purchase a license from them to continue using the program.
You can uninstall and install the program again for you to change the language that is more appropriate for you. And when reinstalling the program be guided on the installation don’t just click next or ok ok read the instructions that is given to you for you not to commit the same mistake again.
Enjoy your stay here and have a good day
I think what you mean by wrong language is that you installed it and then you accidentally selected a different language instead of selecting the right language for you. If that is the case, you can still uninstall it and then reinstall it then select the appropriate language for you. The trial version of Avid Studio has a 30-day trial period so you still have plenty of time to use and evaluate the application.
After the 30-day period has exhausted, this is when you need to completely uninstall it because it will no longer work on your computer or buy the software. If you buy the software, they will send you your registration key for your Avid Studio. You just need to enter the registration key in the application and it will be automatically unlocked and you now have the registered version of the product.
