athan haas
20 points
Posted on - 08/21/2012
Avira Control Center generates the error on the picture I attached. I find it a bit strange because it’s a system error rather than a Realtime Protection error message.
Other software on my PC considers BootSectGui.exe to be clean.
Am I the only one who thinks this is a problem with Avira?
Properties
Realtime Protection: Malware found
Date/Time: 03,07.2012, 09:40:26
Type: Detection
Virus or unwanted program ‘TR/Crypt.XPACK.Gen [trojan]’ detected in file ‘X:program Files’BootSectGuiBootSectGui.exe.
Action performed: Deny access
OK
Hello Athan,
Use the following workaround to resolve the issue that you are getting right now with Avira:
First, you will need to choose the kind of file that you need to scan from the Detection Range section.
After that you will have to choose an action from the Action on Detection section.
And then, regardless of whether you want the detections to be treated automatically or separately, you will need to choose a procedure from the Default action menu.
And then select an action for the infected item: Delete or Move files to quarantine or Ignore until next VDF update.
Next you will need to save your settings and after that close the dialog.
After that click OK and then type your password to allow Avira to save your customized settings.
And then close the preferences window without keeping your settings, and then click Cancel.
Carl
