Avira error the error dialog “avcenter.exe – Entry Point Not Found
I have an Avira error the error dialog “avcenter.exe – Entry Point Not Found The procedure entry point … could not be located in the dynamic link library MSVCP90.dll” I have no idea what these letters for an entry point mean. It looks like a text message from an uneducated teenager.
I don’t know what to do.
Please help me.
Answered By 0 points N/A #150523
I read a bunch of text about this kind of error, and it is getting clear that it`s not your fault. Version 10 Avira has quite a few bugs, and I found some solution that will help you out. What you actually must do go to Windows Safe Mode and uninstall Avira from there. Then reboot into safe mode and run Avira Registry Cleaner. Then reboot into Safe Mode again and install Version 10 Avira. Reboot into Normal Mode and see does this actually work.
If not, remove Avira Version 10 from your computer and install version 9.0.0.442. This should work great for you. Do not attempt to install version 10 until the fix is done.
