Avira’s default settings are having problems
30 points
Posted on - 08/21/2012
Avira’s default settings are having problems. Two reborns and it will automatically “Stop”.
The best solution is switching from “Subsequent Failures” to “Restart the Service” but that doesn’t work.
It will only generate an error “Process Hacker Unable to change service recovery information: Access is denied.”
Is there a way around this one to make things easier?
