Avoid pos link to prestashop site
Hi Techs, Is it possible to include the Prestashop module to a free Joomloa site without having the annoying Point Of Sale hypertext ? (the pos link to prestashop) Thanks a lot.
Go to the program PretaShop and open the following folder directory: modulesblockvariouslinks. Then, locate a file called blockvariousliks.tpl. and open it. The file should have a code similar to the blockvariouslinks.txt attached to this message. Now, open the second text file that I attached to this message: blockvariouslinks2.txt. The line code, {l s='Powered by' mod='blockvariouslinks'} PrestaShop™ has been commented so that it does not show anywhere.
I Hope this is helpful, good luck to you.
Hello Howard!
I am very glad to receive your interesting problem. And I am giving some important suggestions.
You can download the prestashop theme from omega.com. Then you have to install the joomla template.
For resuming your current site you can follow this procedure.
Firstly you need the administrative privilege to enter the back end. Then explore the Extensions. Select the option install/uninstall. Click on browse and select the zip file of your desired template. Then the install button have to be pressed.
Go to Extensions-> Template Manager. Â Â Â Â
Then you will be able to do what to do.
Regards
Shifflett Laurel
