Avoid The Top 5 It Interview Dress Code Mistakes
What are the common IT interview dress code mistakes? I have an interview tomorrow, what should I wear?
The first thing an interviewer notice about you in an interview is your attire, so here is a list of what you should not wear for your interview:
• Never wear t-shirts with quotes for an Interview, as they represent the casual behavior.
• Don’t wear loose-fitting suit, it will make you uncomfortable and may lower your confidence.
• A bright tie, or the tie with a cartoon will be a bad choice for an interview.
• Never wear too much of jewelry for the interview.
• At last, do not wear a hat for the interview. Not even to cover your baldness or the white hair.
