Trent Davis
Posted on - 03/29/2013
Hi, my friend is using AVS video convertor on his PC. But sometimes when converting DVD files on AVS convertor it gets some errors like stuking. Is there any AVS video tools to install and solve this problem. Please can you suggest any other ways also to solve this problem?
AVS video tools for AVS video convertor
Hello Trent,
AVS video converter is a great tool when converting videos. If you are using the latest version of it, the reason for struck may be because of the PC’s performance.
Minimum System Requirements for the latest Version is:
Processor:Â Intel / AMD compatible at 1.86 GHz or higher
RAM:Â 1 GB or higher
DirectX:Â Microsoft DirectX 9.0c or later
And If you are running windows 7 or 8 you will need 2 GB of ram.
If you are looking for other options Wondershare Video Converter is a professional tool. Also if you are looking for a simple and free tool Any Video Converter is recommended.
You can try the AVS Video Converter. It can convert video formats such as DVD, MP3, QuickTime, 3GP, MPEG, Blu-Ray and more.You can also use this on several devices like iPod, iPad, Nintendo, PSP, BlackBerry and more. The editing tools will allow you to rotate your videos, add titles and credits and you can also apply audio and video effects. It can also let you upload your video in YouTube, FaceBook, MySpace. You can get it from the CNET website below:
http://download.cnet.com/AVS-Video-Converter/3000-2194_4-10629027.html
