AWE is currently enabled on a 32-bit instance of SQL Server.
        Hi Team,
When I enable AWE and run it then this error occurred then AWE checks failed and the following error occurs.
Can anyone tell how I may be able to upgrade to SQL Server 2012 with Lock Pages in Memory.
Thanks in advance.
Rule check result
Rule “Is AWE Enabled Check for x86 installations” failed.
AWE is currently enabled on a 32-bit instance of SQL Server. This feature is no longer supported. You must disable AWE before upgrading the instance.
