AweSync software product and facing an error
I was trying AweSync software product and facing an error [error screen shot is here]
This advertised application will not be installed because it might be unsafe
This advertised application will not be installed because it might be unsafe. Contact your administrator to change the installation user interface option of the package to basic.
Please help me out of this anomaly.
Thanks in advance.
Answered By 30 points N/A #174340
Hi there Tony S Boudreau,
The problem you're facing is a well known issue that you can't repair, but you can easily skip instead.
The error appears due to a conflict in Registry on some systems and the workaround is to 'tell' the installation just to perform what's said instead of going through the Registry. To do that, you have to use the installer with only the basic user interface mode.
Best regards,
Drake Vivian
