Azure Active directory office 365- company quota limits
What do I do when my company exceeds the quota of synchronized objects under Azure Active directory office 365?
The number of objects that can be created by an organization is limited by Azure AD. By objects, even groups, contacts and user objects are counted under the quota. The deleted objects also add up to the count for a 30-day tombstone period, after which the tombstone lifetime expires. The limit on the number of objects in the default directory service quota also depends on whether you company has atlas one verified domain, or not. A domain must be added to increase the quota up to 300,000 objects, and not necessary if lesser. By sending a request to technical support for an increase in the limitation, you are allowed to sync more objects. To increase beyond 300,000, contact the support facility online.
