Back up an Exchange server into a tape drive?
What would be the best way to back up an Exchange server into a tape drive? Will NTbackup be enough?
After the installation of your new Exchange server, the next thing you would need to think about is the way on how to back it up. Microsoft Jet is used by exchange to store all of its items. Jet engine can handle multiple databases stored in a storage groups. The database files could not be backed up unless they are mounted.
There are 4 ways you can back up. They are:
·        Online Back up is created by NTBackup which can easily be done.
·        Offline back up involves dismounting the databases and copying it on another location.
·        Brick Level is a backup way wherein backup agent uses MAPI to connect to the mailbox or public folder to do the back up. It can either be offline or online.
·        Tape Drive
There are certainly different means of backing up your Microsoft Exchange Server on to a tape drive. Like for example you have two servers both running on Windows Server 2008, 64-bit on server A and 32-bit on server B.
In server A, you have Microsoft Exchange and in server B it doesn’t have Microsoft Exchange but it does have a tape drive connected to it. In this example, you can use Symantec Backup Exec Small Business Edition and install it on the server which has a connected tape drive.
But you can also create backups on both servers using Symantec Backup Exec Small Business Edition but this would require two different licenses. You can create a backup for server A which directly saves to disk while server B saves the backup to the connected tape drive. If you wish to purchase Symantec Backup Exec Small Business Edition you may visit.
Aristono Martin and Sharath, your comments were gone without saying that it was a genius. Both of your enlightenment were good quality. By going through your impressive comments and example, at this instant I am able to increase my limited knowledge which was my desired question. Your other recommendation was about Symantec Backup Exceup Exec Small Business Edition, I appreciate you and also I am eye to eye with you about this opinion because, I have purchased Symantec Backup Exec Small Business Edition from your provided link and I saw surprised that you are right as well it is the best way to back up an Exchange server into a tape drive. I really appreciated your comments guys. You are providing a very informative sources that could enrich my knowledge. Thanks guys, I believe your comments were the perfect guide to my unknown goal.
