Back up for hard disk
Is it important to make a back up of a hard disk? If yes, what software should I use for the back up and what's the step of doing it?
Hard disk backup is really important for you because any time your computer may go a wrong option, virus attack or total hard-disk failures from where you may lose your important data.
To get a flexible and user-friendly backup system, you may choice Acronis true image software that is very popular over the world. It not only recovers your data but also set again clearly where the data was. After recovering your data you must get your file in same place that would be very helpful for you to browser your computer again.
It's a long tutorial. So I suggest you to see the video step by step:
http://www.top-windows-tutorials.com/Windows-XP-Backup/
http://www.top-windows-tutorials.com/windows-xp-backup-utility/
yes it's necessary to create a copy of a tough disk.Asking what backup program to use is extremely very similar to asking "what's the simplest exercise program?" it's the simplest program for exercise or backup is no matter one you may truly do.You should perform periodic backups to a external USB drive, another pc or use a web service. If you own a pc long enough it'll crash. it's continuously nice to own things secured.I use Acronis to (usually) copy to an external USB HD.Acronis is that the thanks to go. For your audio, i'd investigate using RAID. I conjointly run professional Tools, that i am told is not too RAID happy, thus I bought an external drive that connects via SATA that the RAID is invisible to my computer.
Thanks Bonifacekimeu for a step-by-step guide. I was scared to back-up files and I thought it is extremely hard but with your guide. It is very easy to back-up files. You really helped me!
Thanks Manthew Gard, Bonifacekimeu, and Davidmilan. Thank you for telling me the importance of backing up files and the steps how to do it. TechyV really makes my life easier!
