salvadorjr
30 points
Posted on - 02/26/2013
I have some queries, regarding Back-up software, I would like to ask, what software shall I use, that is capable to back-up open files, the source file will be from a network file server and the target will be a NAS, and this back-up will run daily on a set time.
Thanks in advance.
Sal
Back-up software capable to saved open file
You can try the Leo Backup (Shadow Copy) which is capable of backing up open and also locked files. If its impossible to backup open or locked files and you are encountering "File is in use" error, you can try the 30-day trial of this software. All updates are free. You can get it from the link below:
http://www.leo-backup.com/download.shtml
