Hey guys,
When I tried the realtek audio test my front and sub speakers worked perfectly fine but I can not get any sound from my back speakers. Am I missing a codec or is there anything I can do to correct it?
Back speakers not working with realtek audio test
Hi Timothy,
Based from your technical concern, you are not missing a codec or anything. The rear speakers could be disabled and here are the steps how to check them:
1) Go and click Start and then select Control Panel.
2) Once inside Control Panel, click on Sound.
3) Go to Playback tab, click on the speakers that you used to highlight it and click on Properties.
3) Another window will appear and you have to click on Levels tab. Go check if the rear speaker input has been set to mute and you must uncheck it.
4) Set the volume level to 100 and click Ok. You can now check the rear speaker via Realtek audio test.
I would like to know is the back speaker a woofer or not??
If it a woofer then you cannot identify that the back speaker is being used or not, have you installed the drivers correctly??
I would request you to install the audio drivers correctly and then repeat to check the back speaker, I think that you realtek driver might not have been installed properly.
After following these steps if the same situation arises please let me know
