I made the mistake of upgrading my Microsoft Word because there was a new version. I had no problem with my old one. Now there are only three choices for a background white – off white and grey. These are horrible and make no sense. How can I get additional choices to fix this? Is there a refund option from Microsoft if you do not like the new version?
Background Choices For Word 2013 Options?
Office 2013 has two different versions, RTM and preview version. Unfortunately, if you have preview version, you can select between only three given color options.
Only, if you have Office 2013 preview version on your system, then you can change the background color by clicking on File>>>>> Options>>>> General and under the section 'Personalize your copy of Microsoft Office', now you can select the background you wish to change to and click ‘ok’.
In Office 2013 company decided to let users add a bit a “personality” to their applications with custom backgrounds and themes. There are two versions of Ms Office 2013, Premium and complete. Currently you're using the premium version in which you only have 3 personalize options like white, light gray and dark gray. You can select any one from three by going into ‘File’ ‘Option’ ‘General’ and under the section ‘personalize’.
