Backing up data in zip format with ‘Akeeba’
Hello experts,
I am looking for some help to back up large files in ‘zip’ format. There is a problem with the backup. ‘Akeeba’ is backing up files which are more than 4 MB size, but it is only saving 4 MB in the ‘zip’ file. I think there is some problem with this. I heard that sometimes zipping of files may be failed because of the system limitations. If it is the limitation of the computer can ‘Akeeba’ give an alert?
The backup is completing without any problem in this case. But when I am restoring the backup it gives problems. The JPA is working properly. But it seems very tough to unpack in a Non-GUI Linux server and so I don’t want to use it. Also, sometimes ‘kickstart’ unable to unzip the JPA files. That’s why I am using WinZip.
Any help ?
Tom
