Backing up MS SQL Server causes error
10 points
Posted on - 02/11/2012
My customer installed Ahsay OBM 5.5.8.0 on Windows XP to backup MS SQL Server 2010 in this machine. My OBS server is 5.5.8.0 in version.
During the change to a temporary folder, I found error in the backup jobs. The errors are below:
- Info 2011/04/04 08:39 Start [Windows XP (SQL Server 01), OBM 5.5.8.0].
- Info 2011/04/04 08:39 Start running pre-commands.
- Info 2011/04/04 08:39 Finished running pre-commands.
- Error 2011/04/04 08:39 [Microsoft][ODBC SQL Server Driver][SQL Server]Login failed for user 'sa'.
- Error 2011/04/04 08:39 Database of "(local)" not found.
- Info 2011/04/04 08:39 Start running post-commands.
- Info 2011/04/04 08:39 Finished running post-commands.
- Warn 2011/04/04 08:39 Path "D:Temp1292924031093" does not exist.
- Warn 2011/04/04 08:39 No file is being upload.
- Error 2011/04/04 08:39 Backup completed with error(s).
Please give me a solution if anyone has it.
Thanks in advance.
