gyle kugler
90 points
Posted on - 05/25/2012
I am using sync back for backing up my data. I encountered this problem when I was backing up some music on my PC.
I got an error that said error 'Failed to copy source: Cannot move file (5): Access is denied'.Â
Error:
7-Zip:Internal error,code 105.
While some of the files were backed up perfectly, it refused to back up the rest. I am not sure what the difference is between the folders it allowed to back up and the ones it refused. If you have any idea about this sort of things, please share your thoughts with me.
Thanks for your interest.
Backing Up Songs on PC Problem
Hello Gyle Kugler!
I'm sorry to hear that you are having problems with backing up your files.Â
Usually, for that error to appear, there are several conditions:Â
1.) There are 2 files with the same name running at the same time
2.) The file is corrupted
3.) 2 programs are running the zip at the same time (different from #1)(this is a bug)
suggestions:Â
Try to back up the data in smaller clusters
Do not have any other running applications
Open task manager to see if there's another program running congruent to whenever you open 7 zip.Â
I hope I was able to help.Â
Have a great day
Sincerely,Â
Paul Pinalb
