Backup Data From Linux Partition Using Windows
How can we read, talk, Or backing up important data contained in the Linux partition using windows?
Best Answer by Sharath Reddy
Answered By 590495 points N/A #144208
There are times that I am thinking of trying Linux on one of the computers in our house since it can freely be downloaded from the web unlike Microsoft Windows which costs a lot. But the only problem that I am thinking is its compatibility with the software that I use since most of what I have are all for Microsoft Windows.
Since you want to find some backup solutions for Linux try one of these backup software:
  • Fwbackups – Diffingo Solutions Inc. | fwbackups – this backup solution has a friendly user interface, can do single backup task, schedule recurring backups, and is cross-platform that supports Linux, and Microsoft Windows. When installing on Windows, make sure to read the installation procedure because other components of the software can’t be installed in a single task because of export restrictions. A necessary module needs to be installed separately so fwbackups can function correctly.
  • Bacula® – Bacula.org | Bacula® – The Open Source Network Backup Solution – this is one of the most powerful backup solution for Linux although it is not the easiest one to configure and use.
