Backup device error in windows 2003 server
I am using windows 2007 server for my clients company.we are taking the server backup every weeks with the help of IBM windows tapes connected to one of the server.last day while taking the backup we are getting an error as “backup device error”.can anyone check the screen shots and do the needful
Best Answer by kenedy ker
Answered By 0 points N/A #80426
the error may be in the device manager where the tapes should be mounted in the backup location.go to the computer management,then click the services ,right click on the services ,right click on the removable storage ,restart the removable .once the removable storage device started then go the
storage ,inside that media will be either inside free,import,unrecognized so drag and drop the media inside the backup pool.the particular media must be inside the backup area so that when you started backup is should write on that backup media.try the particular step and you will not get the error.
Answered By 0 points N/A #80427
hi there,
This is error mostly relates to the Final error:0x469 – Physical end of tape encountered.
The cause of this error could be that there is a bad block on the storage media. or an incorrect SCSI ID settings, even incompatible drivers could cause the problem.
I can give you two solutions to the problem.
1.
The RSM or the Removable Storage Manager needs to disabled by going to Administrative tools in the Control panel and Clicking on services
2.
Install the latest device drivers from the manufacturer if disabling the RSM doesn't solve the problem
