I have bought a Samsung Galaxy S4 Smartphone and I want to backup all my personal data and phone settings, I love tweaking phones and backups come in handy, how do I backup on Android? What are the prerequisites?
Hi Debrajbartels,
The 'MobileTrans' software is used to backup the Samsung Galaxy S4 device.
Download the software from MobileTrans official website
The features provided by the software are as mentioned below:
1) It provides sync between iTunes and Android
2) User can backup data as music, video, apps
3) It is useful SMS assistant for message backup in the device
The steps to connect Samsung Galaxy S4 for backup are as follows:
1) Install the software in the computer
2) Connect the mobile phone to the computer through USB cable
3) Click 'One-Click backup' button for the backup process
4) Select the data you want to backup from the list and click 'Backup' button
5) Save all the backup contents in the folder and remove the USB cable
The Samsung Galaxy S4 I9500 is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on March 2013 and released on April 2013 measuring 136.6 x 69.8 x 7.9 millimeters and weighing 130 grams. It is built with plastic body and uses micro-SIM card.
Samsung Galaxy S4
It has Super AMOLED capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution protected with Corning Gorilla Glass 3. It ships with Android 4.2.2 Jelly Bean upgradable to Android 5.0.1 Lollipop with TouchWiz UI powered by 28 nm Exynos 5410 Octa chipset, Octa-Core processor (4 x 1.6 GHz Cortex-A15 and 4 x 1.2 GHz Cortex-A7), and PowerVR SGX544MP3 GPU.
It supports microSD expandable up to 64 GB. It runs on 2 GB RAM with internal storage available in 16 GB, 32 GB, and 64 GB capacities. The primary camera supports 13 megapixels with f/2.2, 31mm (standard), 1/3″, 1.14µm, and AF featuring HDR and LED flash. It supports 1080p video recording at 30 fps with dual-video rec.
The secondary camera supports 2 megapixels with f/2.4 and 31mm (standard) featuring dual video call. It supports 1080p video recording at 30 fps.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP, EDR, LE, and aptX support; GPS with A-GPS and GLONASS support; NFC; infrared; and microUSB 2.0 with MHL 2 TV-out and USB Host support.
It has built-in accelerometer, gyro, proximity, compass, barometer, temperature, humidity, and gesture sensors: ANT+, S-Voice natural language commands and dictation, and air gestures. It runs on removable Li-Ion 2600 mAh battery with standby time up to 370 hours on 3G and talk time up to 17 hours on 3G. It is available in White Frost, Black Mist, Arctic Blue, and Black Edition colors. It supports Qi wireless charging.
1....
