Backup Software Alternatives Other Than Symantec Product
There are several division inside my company that I work for and each division has their own IT policy.
And of the division are using Symantec Backup for backup software from desktop and laptop to the server. I was wondering if there are any other backup software that can be reliable and dependable and cheaper of course.
I was planning to buy a new backup server for it and looking to combine with the backup software for the user to backup their files to the server. Should I stick to Symantec Backup or better to use Windows Backup for it ?
There are going to be around 20 users that will back up their files to the server. The server it self are using Windows 2003 Server. I've heard about SyncBack software too. It seems simple enough but I don’t know if it would be reliable enough compare to Symantec Backup. Have any of you knows the limitations of Symantec Backup ? That would be very useful for me if someone can give me detail descriptions on it and especially how to apply it to both the server ( as host ) and to the workstations ( desktops and laptops )
Olivia
