A Backup Software System For Windows Server 2008 R2
Which is the best backup software system available on the internet which is free for personal use that one can run on the Windows Server 2008 R2?
A backup software is a type of software system that is used by personal computer users and, mainly, businesses to store important data and information into another physical disk that may not be affected by the OS or into cloud for retrieving the same when the primary place of storage fails to open and can no longer be accessed. To do this, you need a software known as a backup software.
Backup Assist is one of the best backup software available on the internet for personal use. It can increment backups to NAS, disk, USB, RDX, network and so on. It runs automatically with email notifications of the same. It takes care of the compression, running of external scripts and advanced filters. It also features remote access. Download/ buy Backup Assist from here:
https://www.backupassist.com/download.php#tab1
Notifications
