Backup using True Image 2010 causes error 0x0004000A
I run 2010 version of True Image as well as often, backup ends. I then get the error code 0x0004000A.
What is this error means?
Please help. Thanks in advance.
To resolve this problem,
1. Either you connect the device used as ACRONIS non stop back up data storage , or
2. Click on Edit non stop back up setting on the main screen.
3. Now, the destination for Non stop back up should be changed, i.e. change the destination for Nonstop backup.
4. Then after changing the destination or connecting the device,
5. Restart Acronis nonstop backup.
This problem is an error code problem. This problem can be solved. First, you have to connect a device with your PC that will provide non-stop back up data storage.
You have to edit the Non-Stop Back Up setting. You have to change the destination of the Non-Stop Back Up. Then, restart Acronis True Image Non-Stop Back Up.
Doing it this way might fix your problem.
