Backup your Gmail on local drive
Dear Techyv Users,
Do any one among you, backup your Gmail on local drive using and configuring it with Microsoft Outlook 2007; If so, I need to know about the step by step process of configuring Gmail in  my systems Microsoft Outlook 2007.
Please do the needful,
Jason K Shivers
Best Answer by Wiley Kolar
Answered By 15 points N/A #186430
The solution is in two steps:
Two things to verify before step 1:
  • IMAP and POP should be enabled in Gmail settings of the account
  • First enable IMAP
  • then enable POP for all mail
  • and 'Save Changes'
1. Set up your Outlook for Gmail account:
  • Now open your 'Outlook 2007' to add new e-mail account
  • click 'next' to start setting outlook
  • Choose 'Yes' and click 'Next'
  • Click 'Next'
  • Click 'Next'
  • Add your account info for user info and logon info for your account and for server in to fill as in the image. Click on 'More settings'
  • Click on 'Advanced' tab
  • Fill in the info as shown in the image, for server port number
  • Click in ok and now you are ready to sync you Gmail with the outlook.
Second part is to back up the emails form Outlook of your account:
  • First download this tool 'Personal folder backup' and install it on your pc
  • Now go to the 'File' menu and click on 'Backup', and you will be able to back up
That's it you have successfully set up Outlook and took a back up for Gmail.
Answered By 0 points N/A #186431
It is very easy to configure Gmail Account in MS outlook 2007. Follow these simple steps and get your Gmail account configured in just a min.
Step-1: Go to tools -> Accounts settings.
Step-2: Click on New.
* Do not change the default settings of any button.
Step-3: Click on next button.
Step-4: Enter your Name, Gmail Account and password. Now let Ms Outlook do the rest for you. It will automatically set all outlook fields accordingly. Finally click on finish button. A test email would be automatically received when you will open Ms Outlook 2007.
