Hello experts,
Recently I made some changes in my Windows hoping my PC will run better and I will get better performances. It worked fine for two days when this morning I got this error. I press OK and this error appear again and again. I did some researches on the Internet I found nothing. Can anyone help me to fix this please without reinstalling my Windows? Can this be solved without losing any data?
Thank you!
Bad data in imatest.ini. Please remove.
Error parsing the file for keys:
C:UsersNormanAppDataRoaminglmatestimatest.ini: Error using ==> infile>findkeys at 508
unknown string found at line 2
The bad line Flagged above was detected in imatest.ini.
Please edit and remove it. The editor will open after you press OK.
OK
Bad data in imatest.ini please remove error parsing the file for keys
If you did some changes to your operating system to improve the performance then maybe something went wrong or maybe caused by one of the programs you installed for improving the performance. If you will check the error message, the issue is triggered by the application called Imatest. If you installed this program to improve the performance, maybe you installed the incorrect version for your operating system.
Check if your version is compatible with your operating system. To make sure you are using an up-to-date version, download Imatest Master 3.10. The download is only a trial version that can be used for 30 days for unlimited tests. It supports Windows 2000, Windows 2003, Windows XP, Windows Vista, Windows 7, and Windows 8 both x86 and x64.
For Mac users, you can use it if you have Virtual PC version 6 or 7. It will not work on Windows 98 Second Edition and Windows Millennium. Once downloaded, uninstall Imatest and then restart your computer. Install Imatest Master 3.10 and see if it works. Also remember that once the 30 days period is consumed, the program will stop working and you will no longer be able to use it.
You need to purchase it by visiting the site again to continue using it.
