This run-time error appeared when I turned on my PC. Is not my first DLL error and I think I solved once and for all the DLL errors with DLL fixer. I think is not working as I expected but can anyone help me to fix one? Why I have DLL errors? Can this be solved forever?
Thank you!
Bad DLL Call
ERROR: Function call has invalid parameter (step number 3, max=2)
OK
Bad DLL Call ERROR function call has invalid parameter
This is really a problem because the DLL file that caused the error was not indicated in the error message. It could be any of the DLL files stored on your computer. Your best option here is to check if you recently installed an application because that’s most likely the cause of the error. If you recently added a program on your computer, try reinstalling it.
Uninstall the application then click Start, All Programs, Accessories, System Tools, and click Disk Cleanup. Select drive C and click OK. Check “Temporary files”, and click OK. Wait until it is finished and restart your computer. After booting check if the error will come back. If it doesn’t appear then your program is really the one causing it.
Install it back then restart your computer. This is just to check if the error comes back. Just in case the error appears again, it would be better to just uninstall the program.
