The BADAPP has stopped working
Hi there,
Fresh RAM is used to enhance the performance of the computer. However, an error message always appears that is so annoying. The message tells that the program cannot work correctly because of a problem.
This message is very disturbing, especially when I work in the middle. I still do not have any solution even after calling the support center.
So please help if anyone has experience with this software with same error. Many thanks.
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available.
