Badly need some SAS base STAT decision tree code.
Hi there, I'm looking for some SAS based decision tree codes. Can anyone help me finding those SAS base STAT decision tree code?
Answered By 0 points N/A #163837
From your description I come to know that you want a SASbase STAT decision tree code.
I don’t know about the configuration of your computer and also unknown to me that which version you want to use for.
You can use DTREG for state decision tree code.
You will get these items from the URL
  • Features of Decision Tree Based Models
  • Features of Neural Network models
  • Features of Support Vector Machine (SVM) models
  • Features of Gene Expression Programming – Symbolic Regression models
  • Time Series Analysis and Forecasting
  • DTREG Features
  • Ease of use
  • Classification and Regression Trees
  • Single-tree, Tree Boost, Decision Tree Forests, Support Vector Machine, K-Means clustering, Linear Discriminate Analysis, Linear Regression and Logistic Regression
  • Automatic tree pruning.
  • Surrogate variables for missing data.
  • Visual display of the tree.
  • DTREG accepts text data as well as numeric data
  • Data Transformation Language (DTL)
  • Project files for saving analysis
  • Scoring to predict values
  • Generated scoring source code.
  • Heavy duty capability.
  • DTREG COM Library.
Hope your problem will be solved soon.
