Bandwidth for Running Cisco WebEx Video Conferencing
I will be using Cisco WebEx Video Conferencing on T1. I want to know how many bandwidth it requires when using a DSL. How many T1 is required to run this? Any help will do. Thank you.
You will need to have a higher network bandwidth to run the video conferencing application, and that is so as to provide a high quality video for the conference, and also provide higher speeds at which the videos will be streamed to avoid stalling and freezing problems. A minimum of 2 GBPs will be ideal to provide the best video quality and faster speeds, but the more the bandwidth will make it even better. You should not go down and use very low bandwidth especially in an environment where there are many users that are meant to use the facility, for that will tremendously slow the speeds and make the video quality poor.
Regards
Thompson Locker
Notifications
