Bartender mix genius how to have 7000+ points for iPhone?
Has anyone tried getting 7000+ points for bartender mix genius? Does anyone know the right combination to achieve this? Any kind of help would be appreciated.
Hi Emsley,
Here are some hints to get 7000+ points in Bartender Mix Genius:
The right mix:
Combine vodka and cranberry juice with other mixes to get a score of 6000 – 8000.
Heavenly Drink:
Fill the glass half with vodka and the other one with cranberry juice and add a little ice. And then shake a little.
Rock star:
Combine Vodka, Cranberry and lime juice, Gin and ice. But remember to add more vodka than the other mixes and the least is the lime. Add a lemon garnish. If you can do this correctly, the bartender will hit his guitar and play a rock music.
Make the bartender a Dragon:
You just need to put a bunch of ice until the glass is full and then shake it until it gets louder.
Boring Party:
Put the ice in and half a glass of tequila. Put cointreau a bit over quarter of the glass. And then top it off with lime juice and shake 3-4 times. Garnish it with a lemon wedge and then serve it.
Big Eyes and Rainbow:
Add Little Passion Fruit Juice. Add lime juice 2x than the passion fruit juice. Add Little Cranberry Juice and a little of Orange Juice. Fill with vodka but leave enough space for ice cube.
Hello Emsley,
Bartender mix genius is a nice game, but it need to be more advanced or complex. When playing the game, it offers you no hint for making a better mix. Every drink at the moment seems like a cosmopolitan. For instance, if you pour 1/2 Absinthe you will still be told that it needs more vodka, or it adds more bonus items for instance olives if there are not in there already.
Otherwise the clue to coming up with 7000+ points is as follows: You will need to mix 35 percent cranberry juice, 25 percent lime juice, 20 percent tequila, 15 percent vodka and ice. After that you will shake and then add a lemon upon serving. That's it. You will have garnered yourself 7000+ points.
Carl
If you play “Bartender Mix Genius” on your Android phone, here’s how to get some high points aside from the 7,000+ points you want:
To help you with other tricks on playing the game, try watching some of the Bartender Mix Genius Videos.
