sheilanbarr
10 points
Posted on - 09/10/2012
I just would like to know what is the best WMA to WAV converter that I could possibly use that is fast, reliable and tested my many users out there. I have a bunch of files to convert.
Based on wma to wav converter reviews, Which one is the best?
Among the Top Four (4) MP3 Converters, this software ranked as the Top One (1) MP3 converter.
Easy to use interface and has first-rate audio format support. It can switch WAV, WMA, MP3, OGC, AAC, FLAC, AC3, APE, and M4A. Generally, it is an enormous tool that does a first-class job. It is a worldwide audio converter. Plus, there is also a CD slitter device that is also mounted on your system that you can apply to slit music CDs to WAV, OCG, and MP3 file.
Best regards,
Heather Marie
Hi Sheilanbarr,
You will find a lot of audio convertor on internet. Let me give you a list. They are one of the best what I had been using.
1) Free Studio Manager: Converts almost all sounds formats and also supports wma to wav format. It is good from point of view of performance.
2) Zamzar : It is online solution for conversion of audio files. Supports wma to wav and vice versa
3) YouConvertIt: It is a online audio conversion site. It supports wma to wav. It needs a healthy internet connection to get things done.
There are some magnificent and lighting fast software's which allows you to convert your wma file to wmv. I personally suggest 'Boxoft'. It's a wma to wav converter. It's a smart and popular converter which lets you convert your wma to wav and many more format. Like MP3, WAV, OGG, MPA, MP2, AU, AIF, and many more. It can also extract audio from many video formats to WAV file, such as MPEG,WMV, ASF, DAT, VCD, SVCD,XVID.
All you have to do is:
1) http://www.boxoft.com/wma-to-wav/ – Go on this site
2) Download the file
3) Install it and change the format.
If you need a converter to convert some audio and video files, here are two converters you can use. Download Format Factory on MajorGeeks.com. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. This software is a multi-functional media converter that is able to convert both audio and video files.
Supported audio formats include MP3, WMA, AMR, OGG, AAC, and WAV. Supported video formats include MP4, 3GP, MPG, AVI, WMV, FLV, and SWF. It also allows you to rip video DVDs and audio CDs. Note: read before clicking when installing Format Factory to avoid installing unwanted software. This program is bundled with several other unknown applications and tools and can display ads within the application itself as you use it.
You can also use ImTOO MPEG Encoder to convert your media files to another format. It supports Windows XP Service Pack 2, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It requires 1 GHz or faster Intel or equivalent AMD processor, 256 MB RAM, 50 MB free space, and 16-bit video card.
