Mike Joseph
30 points
Posted on - 08/06/2011
Hey People,
I have Just learnt the Basics of C++.
I have recently written my first program.
What is the difference between the two codes..
Code 1
cout<<"Hello" <<"t" <<"world";
Code 2
cout<<"Hello World";
Also How do I test the output of a C++ file?
Thank you for your Help.
Mikey
Eemmy
Basic Doubt Regarding C++ Programming
Nice to hear that you are learning some programming stuff.
The question post is very nice and my answer could be as follows
Code 1
Ans: Outputs with Tab space in between Hello and World where as in the Code 2 there will only one space as given in the code.
Code 2
The code you have given is called as a statement in programming stuff, a statement is a simple or compound expression that can produce the some results accordingly. cout is the name of the standard output stream in c++ which inserts the sequence of characters into the standard output stream.
Press Ctrl+f7 to compile your code and press Ctrl f9 to execute your program . Or you can find the execute command in your editor.
Thanks
Eemmy
