Basic Information on Backup & Restore on Android
I was just going through the settings app on my Android Smartphone and under the Personal tab I found ‘Backup & Restore’ option. So I wanted to know that what is Backup and Restore in Android?
In order to make sure that your data is safe, Google introduced Backup & Restore in Android long back. This feature helps the user to backup their data time to time so that if by any chance the data is lost due to installation of malware or some other error, the user can restore their data thus minimizing the loss.
To know more visit this site.
That option you found on your Android Smartphone called “Backup & Restore” is for backing up purposes. You need a PC to use that feature and create a backup of your phone’s data. Unlike the Apple iPhone that provides an option to backup the phone’s data on the cloud using iCloud, in an Android Smartphone, you can create a backup of your phone’s data on your computer.
When backing up your phone to your computer, you need to use the USB cable that is included with the phone when you bought it. Aside from that, you also need to install the Smartphone’s software which you can always download from the phone’s manufacturer’s website. You won’t be able to use the “Backup & Restore” feature if you don’t have the phone’s software installed.
Aside from using the “Backup & Restore” feature to create a backup of your phone’s data, it is also used to restore your phone’s data if something bad happened like some data were deleted on your phone or you needed to factory reset your device to get it running again after a fatal crash. If you have a Samsung Smartphone or device, you need to download Samsung Kies Phone Software.
