Basic Information on using Corel 10 Barcode for labeling
I'm in the process of branding items for sale and would want to consider labelling with barcode. Trying to find someone with knowledge of this product. Is there anyone familiar with Corel 10 barcode?
Answered By 0 points N/A #147539
There is software intended for bar coding. We all know that all products have a control numbers or code for a specific item. Using Corel or any version of this software supports bar coding. In using Corel 10 or Corel X, on the menu bar of Corel X click ‘Edit’ then select ‘Insert Barcode’, after which key in the code depending on what you have chosen on the Industry Standard Formats. Then click ‘next’, and then it’s up to you to modify the default values, then click ‘next’ again  it’s up to you again to modify then click ‘Finish’ to Insert the barcode or you design.
Regards!
