The basic procedures to consider in servicing computer speakers
        What are the steps to follow in servicing computer speakers? I have a computer speaker which has a USB cable as its power cable and I would like to change the tip to a normal power cable socket. What are the precautions to consider in order to fulfill this task? What are the likely challenges to occur after this conversion or alteration? Thank you.
