Basic questions regarding Database which are very necessary for all.
Hi All,
- What is database and relational database?
- What is a form and filter? And mention its advantages.
- What do you mean by Table, Record, Field and quires?
- What is the difference between data and information?
- What are validation rules and why do we use validation rules?
- What is the difference between text and memo data type in MS Access?
- What do you mean by primary key? And describe its advantages.
- Why are indexes used in table?
- Why do we relate table?
- How can we prevent duplicate data to be entered in a field other than using primary key?
