Basic Requirement For Supreme Commander 2 Manual
Can you give Supreme Commander 2 manual in a DVD player? My son wants to play it eagerly. Please help me to use it.
Supreme Commander 2 is a video game developed by Gas-powered game and published by Square Enix. If you are using a DVD player, insert your DVD into the computer or a laptop. The installation screen will appear. It will direct you to how to install the game. If it does not appear, you can go to my computer, and you can click on the disk drive having Supreme Commander. You need to click on the setup.exe to launch the installation screen. Once you’re done, you can now play. Few tips that would help you to understand and play game faster;
With the shift command and control, you can attack the person. There are 3 Techtree you need to build factories and then build an engineer will take you a higher level of Techtree. You can zoom in zoom out and have a full view of the area you want to consider. Camera control is inserted by holding space key bar and moving the mouse you can change the field.
